327baler with#30 kicker
oswaldo
08-15-2005 05:02:05
kicker was missing bails local dealer said to replace valve ,also replaced springs know it wont go back to home for next bail any ideas thanks
jd 328
08-15-2005 20:16:11
 Re: 327baler with#30 kicker in reply to oswaldo, 08-15-2005 05:02:05
I have a 40 kicker, so I'm not sure if the 30 is the same, but should be pretty close so heres a few options. I had the same origional problem as you and heres what the daeler service man did. If all the linkage trips, but the kicker doesn't go try manually tripping it with the small lever that sticks off the linkage by the valve(If the 30 has this!) it should kick. If that worksthen... On the valve there is a small hex plug with a spring under it. Remove the plug and clean and grease everything up good. Not sure where the plug is exactly, but I don't think any oil comes out with it.
If the pan doesn't come back the bale length could be too short or the valve may be houlding pressure on the cylinder. If the pan falls by itself, check bale length or the catch that holds the pan in the home position. If the pan stays all the way to the top if its cycle check to see if the valve is holding pressure on the cylinder. When the kicker kicks and doesn't return slow down the tractor and listen to see if the hydraulic pump is drawing power. This should be noticable compared to normal operating sound. If this is the case your valve needs some work, and I'm sorry to say I can't help you there! Sorry for all the options, but I'm not sure how much you have looked into the problem. Good luck! let us know what you find.
