Deere Dave, I agree with Bob,,,,I dont see polarity as the issue or problen on that starter motor. The reason it still turns the same direction REGARDLESS of polarity is because the magnetic field in its poles is an electromagent developed by current passing through its field windings, and the magnetic field thus developed indeed has a certain North/South polarity which depends on what direction the current flows. HOWEVER, when you swap polarity, you DO NOT reverse the relative N/S polarities BETWEEN the Armautre windings and Field Windings, therefore, the magnetic attraction and repulsion which determines which way it spins STAYS THE SAME. To make it turn the other way, you would simply swap ends with the Field windings which changes the magnetic polarity N/S attraction and repulsion, but as you know, those motors dont have the Field windings posts brought out individually where you can even get to or swap their wiring. Nowwwww ww if the motors Field poles were NOT electromagnet but a fixed Permanent Magnet with a fixed N/S polarity, if you swapped polarity changing the direction of current flow in the armature wibndings (remember the Field magnetic polarity dont get changed, its a fixed permanent magnet), SHE WOULD SPIN BACKWARDS cuz you have changed the relative N/S attraction and repulsion. Sooooo oo tell them nay sayers YOURE RIGHT AND THEYRE WRONG LOL Finallyyyyy yyy If the motor does not crank and its okay,,,,, , it must be a solenoid (if it has one) or a mechanical starter switch (if it had one) or a wiring or connection related problem. Insure the starter cable is good and has good clean tight connections (remove n clean n wire brush n reattach) and do likewise for the ground cable making sure its to a good solid frame member versus any rusty sheet metal seat or battery box. If it has an electric solenoid, try jumping direct to the starter, which by passes the solenoid, n see if she spns then: CAUTION thats a high current draw so you gotta get good solid connections and beware of arcing, I would have the plugs removed so she cranks easier. If the starter then spins you may have a bad solenoid. To test it jump a hot wire to its lil activation terminal n see if she cranks then?? If not assuming the solenoid is well grounded?? It sounds bad. If it cranks when you activate the solenoid with a hot wire but NOT when you push any starter button or key etc. either the button or the circuit from it down to the solenoid must be bad. Place a test lamp on the solenoids lil activation terminal (S) and when you push any starter buttin etc IT MUST LITE UP or the circuit or push swtich or the hot feed to the switches input is bad or not there. If its a mechanical push switch inspect it for burned contactor or that the starter post is clean n not all burned up n carboned. If you swapped to Negative ground any ammeter leads need to be swapped and if it has a Generator re polarize it and wire the coils as if its a negative ground system now. John T
