Re Oil capacity of 50 AR
Bigolebear
08-14-2005 22:09:41
Can anyone give me the capacity of the gear box/rear end, and the engine oil, for a 1950 AR?
If you have a manual Where are the plugs to check the levels? Thanks
Glen in TX
08-15-2005 10:56:32
 Re: Re Oil capacity of 50 AR in reply to Bigolebear, 08-14-2005 22:09:41
It would help you a lot to get a copy of the OMR2004 Operators Manual thru your JD dealer or by calling 800-522-7448. Engine crankcase holds 8-11 quarts and there is a test level cock on side of engine for checking it. After changing oil and filter add oil until it comes out of the test cock and close it and then add another quart for the filter. Transmission holds 8 gallons. A operators manual will show you locations of these and power-trol and what oils to use and grease fitting locations and many other useful maintainance needs as well.
