JD 3010 Hydraulic Pump Mystery Fitting??
Charles Beavers
08-14-2005 16:42:40
I have a 1961 John Deere 3010 and see what looks like a 1/8" ID flare elbow on the bottom of my hydraulic pump without any piping attached. This fitting is not quite dead centered (more to the right side and rear of pump) on the bottom of the pump. It drips a little hydraulic oil (maybe about the size of a siver dollar per day). Can anyone tell me if this fitting is there for a reason or can I plug it off?? I am surprised if it is a flare fitting, that hydraulic oil doesn't busrt out of it continually. Could it have a check ball inside sealing majority of oil??
Your help will be greatly appreciated!!
msb
08-14-2005 18:50:38
 Re: JD 3010 Hydraulic Pump Mystery Fitting?? in reply to Charles Beaverson, 08-14-2005 16:42:40
You will probably laugh at this ,but it is a drain line for the main pump shaft seal.Since Deere couldn't get the seal to consistently hold, they simply drilled and tapped the area just outside of the seal.There should be, as the other posted says,a small, black plastic line attached to the fitting and the other end attached to the brake valve on some tractors and the transmission case on others.Some of those engineers were obviously farmers too.You can probably find some clear vinyl tubing that will go over the fitting and the black tubing since the oil is under no pressure.I keep a piece of the old green tubing out of a 494A planter preemerge kit to use as a splice.It makes a perfect splice.
Glen in TX
08-14-2005 18:24:29
Look under it more to see if you got a line broke off. I'm thinking it's for that black plastic return line to the RH side of transmission that was used on most 10 & 20 series. It goes inside the frame rails back to the transmission.
