Another JD B Timing Question
Larry Jensen
08-14-2005 16:14:20
Are the cam gear bolts offset so the gear will only go one way? I have located all marks on the crank and both inside and out marks on cam gear. The cam and crank are out of time according to the marks.
Lee B
08-15-2005 20:38:02
 Re: Another JD B Timing Question in reply to Larry Jensen, 08-14-2005 16:14:20
I don't believe they are offset such that it will only go together 'in time'. I'm thinking your odds are 66.6667% that you can get it wrong? Don't forget that you have 'LH exhaust open' mark on the flywheel to insure your camshaft is in the right position. LH is Left Head or number one cylinder which is on the flywheel side. When that mark lines up with horizontal timing mark on the tractor, the exhaust valve should just be beginning to open, and not fully open.
