4640 cracked cast center removal
Fred Turner
08-14-2005 15:25:09
I have a 4640 and one of the cast wheel centers is badly cracked. I bought a used one from a junkyard and would like to replace with the cracked one. The center I have on the tractor has a 1500lbs. weight bolted to the inside. How do I safely swap the centers and put the weight on the new one?
Fred
JDBert
08-15-2005 12:49:29
 Re: 4640 cracked cast center removal in reply to Fred Turner, 08-14-2005 15:25:09
I would remove the rim and tire, loosen you cast center and move it out to the end of the axle, and then either using a forklift or loader hook up to the casting and take it the rest of the way off. Lay the center down on its face (lay your new one next to it), unbolt the weight pick it off the center and move it to your new one and bolt it back on and put it back on the tractor. Put your tire and rim assembly back on and move the whole assembly back to your row spacing and tighten down. Make sure you have everything blocked and jacked good because your gonna be dealing with about 2000 plus pounds
