Ever try an electronic ignition kit for 2 cyl JD'
Fred from MO
08-14-2005 11:30:09
I was wanting to know if anyone has ever tried one of the electronic ingition kits for the old 2 lungers that this website sells through their parts listings? Anyone has any Pro's or Con's with a system that they have installed?
buickanddeere
08-15-2005 06:08:16
 Re: Ever try an electronic ignition kit for 2 cyl in reply to Fred from MO, 08-14-2005 11:30:09
Yes but..... ..... .. Taking a B ,adding an electronic ignition, a straight exhaust stack, an A's carb and filling the tank with racing gasoline. Isn't going to make it outpower a G on the pulling track.
Chuck Westerfield
08-15-2005 04:40:53
you need to buy the matching coil to get best results. I purchased from Genessee Electronics. It is a permanent fix and you don't have to mess with points. Get the kit that matches your setup, positive/negative ground and type tractor. I believe you will be pleasantly pleases. You can detail the setup and no one will notice change from factory. Idle is much smoother as you don't have bouncing points to contend with.
Fred from MO
08-15-2005 16:44:06
 Re: Ever try an electronic ignition kit for 2 cyl in reply to Chuck Westerfield, 08-15-2005 04:40:53
Does Genesis have a website or do you have a contact number for them?
ChuckW
08-14-2005 18:15:24
I've put on 6 kits and it is overwhelming as to results. I ran a water hoze on the distributor then started tractors....try this with conventional...get out about 40,000 volts and will fire through unleaded and eliminate plug fouling.....
Fred from MO
08-15-2005 02:35:04
 Re: Ever try an electronic ignition kit for 2 cyl in reply to ChuckW, 08-14-2005 18:15:24
Did you buy one of those "Flame Thrower" coils that they sell on this site as well to get 40,000 volts or was the increase just from the electronic conversion kit?
JDSixty
08-14-2005 18:07:05
Put one on my 60 and think it was the best move I ever made , I added a 65 amp alt. to help keep enough voltage to feed the beast.
Fred from Mo
08-15-2005 02:32:23
 Re: Ever try an electronic ignition kit for 2 cyl in reply to JDSixty, 08-14-2005 18:07:05
I want to put one on my 60 as well. What changes did it involve to the system? Did you purchase a new coil for it as well? What made you decide to put on an alternator instead of the old generator?
JDSixty
08-15-2005 09:16:47
 Re: Ever try an electronic ignition kit for 2 cyl in reply to Fred from Mo, 08-15-2005 02:32:23
I didnt think that the generator was charging enough to keep the bat. hot, I pull this tractor and I wired the alt. up so that I am abel to cut it off and turn it back on at the end of the pull. I do not run very many fliuds (3 gal. water,1.5 gal. rear oil and 1.5 gal. gas) at one time just to keep the wight down and the alt. is lighter than a gen. and recovers the bat. at a quicker rate. I did put the hotter coil on and a resister also. It was not a very hard job to do.
Hayfarmer
08-14-2005 16:00:05
Have one on my JD 430 and it works great on it. Not use one on the Horizontal piston ones.
Rah
08-14-2005 16:49:06
 Re: Ever try an electronic ignition kit for 2 cyl in reply to Hayfarmer, 08-14-2005 16:00:05
The person that sets bearings, fits rings etc for me put one on his A and likes it.
elv8orman
08-14-2005 17:57:40
 Re: Ever try an electronic ignition kit for 2 cyl in reply to Rah, 08-14-2005 16:49:06
Installed electronic ignition on my 620, along with a new coil. Best move I ever made. Never fails to start now.
