How best to support front end of JD 4010?
RFox
08-14-2005 11:00:27
Hello everyone,
I'm probably going to need to remove the front axle from my JD 4010 to do some work on the hydraulic pump. Would heavy duty (12,000 lb) jackstands be the way to go in supporting the front end? Is there a better way?
Thanks Alot!
BuyGreen
08-15-2005 17:41:53
 Re: How best to support front end of JD 4010? in reply to RFox, 08-14-2005 11:00:27
Well, you can't be too careful, I would use more than one device to hold the tractor. Good luck to you, be EXTREMELY careful, something that heavy can kill a man in a second.
As far as lowering the pump, when you remove the pump (which is very heavy) you could probably use something like a hydraulic lift table to lower the pump.
A buddy of mine is going to get his from this site:
Link
gwece
08-15-2005 11:32:51
I replaced my 4010 hyd pump last year. Used chain hoist to support front section from overhead beam in shop (with safety support blocks under frame). If you have a wide front end, you might consider leaving one rear corner bolt in and swing the front end to one side out of the way. If you end up removing the pump, take it AND the mounting bracket out as one unit. Shop manual doesn't tell you this, but the pump will not come out by itself due to lack of horizontal clearance. If you are expecting to work on the pump in place, remember that it will only be accessable from below due to the metal plate underneath the fuel tank. Good Luck!
msb
08-14-2005 11:28:08
If you can't borrow,beg or steal a regular OTC splitting stand, then I would use some 3" angle iron to make one and BOLT it in place.Nothing scares me more than to see a tractor setting on top of jack stands without the tractor firmly bolted to something.
txgrn
08-14-2005 18:10:15
 Re: How best to support front end of JD 4010? in reply to msb, 08-14-2005 11:28:08
I agree. Any kind of sturdy stock will work. I used 16 ga 2" square tubing for my last one. Just took a minute to cut it out and weld it up.
Mark
txgrn
08-14-2005 18:12:35
 Re: How best to support front end of JD 4010? in reply to txgrn, 08-14-2005 18:10:15
Forgot. Brace it in all 4 directions. I built a square (for the vert part) then made 2 perpindicular legs so that it couldn't tip in any of 4 directions.
Mark
RFox
08-14-2005 20:13:29
 Re: How best to support front end of JD 4010? in reply to txgrn, 08-14-2005 18:12:35
Thanks guys! Good avice!
