Darren -- You say the tractor runs fine "at idle but anything over that - - -" Will the engine fast idle? Does the engine run "up to speed" okay but just hasn't any power? Did you check the linkage adjustment between the governor & carburetor? Now, "Branson Enterprises" -- did they mount the carburetor onto a test engine & run it up before it was returned to you? Did you run the LOAD & IDLE path tests on your carburetor to ensure both paths are indeed open & functional? Some specific answers here & then a repost may help us help you better. In the meantime, I will follow with two procedures for you. Beyond these, it 'smells' like a "pressure differential" issue in your fuel bowl -- like a bowl vent path not fully opened!!! Get back to us after running the tests below.(PatB) 37. Testing -- LOAD & IDLE Pathways You can test your carb's IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: a. CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. b. With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below. c. With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked. ++++ 38. Governor Linkage Adjustment a. Free up and align all linkage to remove any binding. Adjust or renew any parts causing lost motion, and disconnect throttle rod at carburetor. b. With hand control in full speed position, adjust the length of the carburetor throttle rod so that the rod is 1/2 hole short from entering hole in carburetor throttle shaft lever when carburetor butterfly is in wide open position. Reconnect throttle rod at carburetor. ++++
