JD 214 - Won't cut
SwingKitten
08-14-2005 08:13:44
I bought a JD 214 at a silent auction (sight-unseen) and it turned out to be in terrible condition. With a lot of help from my uncle, we got it running. When I finally went to use it, it ran fine and cut for about 1 pass. Then it made a terrible noise, white smoke came out, and it stopped cutting. It will still drive, but it will not cut.
Any suggestions? Should I put it up on ramps and look underneath? (Not that I know what I am looking for since the owner's manual -- which I had to purchase online -- doesn't discuss the deck part at all! And I am pretty sure we changed the drive belt when we were fixing it up.)
~Swing Kitten
donmyeil
08-16-2005 13:07:00
 Re: JD 214 - Won't cut in reply to SwingKitten, 08-14-2005 08:13:44
There's guards around the pulleys thar hold the belt in place undreneath the clutch . If the belt is routed over instead of under the guards , it will smoke the belt right now. You can tear up the belt in a hurry if this is the case.
dirtjockey
08-14-2005 08:31:35
Make sure you have the belt on right. I had one and you can get the belt wrong. It will make the deck turn backwards. Plus it can rub and cause smoke.
