Coolant Electrolysis of JD 2440
Carl Ernst
08-14-2005 06:54:25
I've read your archive discussions regarding electrolysis problems causing sleeve corrosion in older JD tractors. I'm seriously considering the purchase of a 2440 and would like some advice from the forum: Is this corrosion common to all older JD tractors or is the 2440 particularlly troublesome? Would an oil test for antifreeze detect this problem? Are there any other common problems with the 2440's that I should be aware of?
buickanddeere
08-16-2005 19:44:32
 Re: Coolant Electrolysis of JD 2440 in reply to Carl Ernst, 08-14-2005 06:54:25
Assume the sleeves leak. The high price and demand for utility tractors tends to make people hold onto them until $$$ repairs are required. Before opening the wallet for the 2440. Just for the fun of it price a new 5105 M4WD. Likely close to the 2440 and an engine rebuild. Plus it's a new unabused tractor with warrenty.
Carl Ernst
08-17-2005 05:24:20
 Re: Coolant Electrolysis of JD 2440 in reply to buickanddeere, 08-16-2005 19:44:32
I priced a JD 5105 with FWD. List price is just over $23,000. I think I can buy that machine for $20,000. 2440's are all over the place but I'm looking at one (5100 hrs)in the $7-9,000 range. What will an engine job on a 2440 cost me?
Indydirtfarmer
08-15-2005 05:21:01
I've bought (and then rebuilt) 2 different 2440's that were victims of wet sleeve pitting. It isn't exclusive to the 219 Cu. In. Deere 4 cylinder by any stretch. Like it has already been stated, ANY diesel can have the conditions present that CAUSE the problem.
There is no way to tell how much, if any damage is present without pulling a sleeve, UNLESS the sleeve(s) are already perforated. Then it's too late.
First step in diagnosing a potential problem would be a simple PH test of the coolant. If it's not right now, chances are good it's been allowed to be that way for a great deal of the tractors life. Deere sells a coolant treatment, as well as Fram, and several other companies. Also, Deere makes a kit for the 4XXX series tractors that employs a filter to keep the coolant system free of rust particals and dirt. (Which is a contributing factor in electrolysis) The kit is easily adapted for use on the 2440. (If interested, I can send you pictures of my installations) The kit uses a simple spin-on filter, very simular to an oil filter.
One further test to pinpoint small leaks is to remove the oil pan, then pressurize the cooling system. Look for small bubbles or traces of water/anti-freeze near the base of the sleeves, near where they press into the block casting.
Besides the visible "water-in-the-oil" test, look at the crank-case breather tube (near the step on a 2440) for traces of moisture being blown out the tube while the engine is running.
Carl Ernst
08-15-2005 18:04:17
 Re: Coolant Electrolysis of JD 2440 in reply to Indydirtfarmer, 08-15-2005 05:21:01
Thanks to all for the very helpful info. Regarding the ph of the coolant, what ph range is normal and at what ph should I be concerned? Will a simple litmus test be sufficient? Also, where do I send oil samples for analysis? JD, AmSoil?
txgrn
08-14-2005 18:16:38
Electrolysis is a problem in all wet sleeved engines. But mother deere has a pint bottle of treatment for like $3.50 that treats one large tractor. Is supposed to prevent it. It also helps to run 50-50 antifreeze solution or better and only use distilled water, not tap water (minerals in tap water).
Mark
Roy Suomi
08-14-2005 10:36:52
There is no way of checking for internal liner erosion without a teardown. I worked for Deere for many years and did many engine jobs because of coolant in the crankcase. If it's leaking the oil will be gray in color. You shouldn't need to analize the oil . The color is a dead give-away. Any and all diesels with wet liners are suseptible to this problem. Many diesels without liners have this problem, so better off with wet liners.Best maintenance is to use coolant conditioner to change the ph of coolant to prevent this situation..
Carl Ernst
08-15-2005 05:11:03
 Re: Coolant Electrolysis of JD 2440 in reply to Roy Suomi, 08-14-2005 10:36:52
Roy, Thanks for your input. From your comments it sounds like a grey color in the oil will tell if the tractor has a major coolant leak into the engine lube system. However, what if the leak is minor or if the dealer recently changed oil would the grey color still be present? If not wouldn't an oil test give evidence of a major problem to come? Also, from your experience are there any issues unique to the 2440 that I should be aware of?
bryan s
08-15-2005 07:16:14
 Re: Coolant Electrolysis of JD 2440 in reply to Carl Ernst, 08-15-2005 05:11:03
ive seen oil samples with antifreeze being present with out it be noticable by eye..... ...have it checked!!
Henry J
08-14-2005 11:07:38
Roy
Talk about a crap shoot. You could buy that tractor and the sleeve wait to eat through as you are unloading it from the trailer.
But that is the way it is.
