210 JD kohler engine question.
dmt
08-13-2005 16:00:47
I just overhauled my 210. .010 over, new rod, carb kit. After running for bout 45 min it gets to sounding like a diesel knock is occurring. It starts hard when completly warmed up too. Ive changed oil 3 times now in 3 hours. There still is a hiny of glitter in it, is this normal? Thanks.
Maark
08-14-2005 09:01:50
 Re: 210 JD kohler engine question. in reply to dmt, 08-13-2005 16:00:47
As long as you timed the camshaft to the crankshaft, the only other way that timing is changed is by point setting. The silver filings could be from the boring process, not all of the filings were flushed from the block after it was bored.
dmt
08-14-2005 07:29:23
I retorqued the head bolts after it cooled. I set the points at .020 gap. Does anyone know how I can change the timing? and where the timing mark is if it has one? I think this is my trouble. and the starting problem when warm. Thanks!
Bob
08-14-2005 08:47:03
 Re: 210 JD kohler engine question. in reply to dmt, 08-14-2005 07:29:23
Here's a link to a free on-line manual (in .pdf format).
Timing information is on page 72 and 73. It is a little confusing, in that the heading is "Magneto Ignition Timing". The next heading is "Battery Ignition Timing, where it tells you the procedure is the same as "Magneto Ignition Timing".
Bob
08-13-2005 22:31:05
Assuming the rod is OK, as you say, retorque your cylinder head. (A head gasket leak on these can sound like a knock.)
Did you set the timing according to directions, with a timing light, by varying the breaker point gap?
dmt
08-13-2005 20:16:44
I just got the pan off and checked things out again. I have .0025 oil clearance on the rod. The crank is not egged at all. A slight bit of rod side clearance. No scoring on the cyl wall. I'll be damed if I can see where the glitter is coming from. It all looks very good and checks out per Kohler specs. Any ideas? Thanks.
Donny-B
08-13-2005 17:32:30
dmt, Doesnt sound good. Did you check the crank for egg shape before assembly? Was the rod clearance checked? Oiler hole on the correct side? Did you torque the rod bolts properly? Sometimes the nuts come loose after initial startup. I use high temp loctite for my own piece of mind. I would pull the pan and check things out before you have a blow up. Good luck.
donmyeil
08-13-2005 16:52:28
Sounds like trouble in river city, better pull the oil pan and have a look. Did you put the rod in the right direction? If its backwards they wont oil very well. just a thought. Don
Mike M
08-13-2005 16:04:51
Doesn't sound normal to me ! How was your rod clearance. I was reading a post maybe over on the garden tractor board about a fellow having trouble with his rods dippers hitting the bottom and breaking off. May be some too long rods out there ?
