Installing Magneto on Tractor Part 1 -- Tractor setup:
1. Remove No. 1 spark plug (flywheel side), & No. 2 also for safety. 2. Place your finger over the hole (flywheel side) and rotate the flywheel in the forward (running) direction until you feel a pressure build-up of air in the cylinder. Turn your attention to the timing mark to the rear of the flywheel. 3. Continue turning flywheel until the "L.H. Impulse" mark, stamped on the flywheel, lines with timing mark on the tractor; then STOP. Tractor mark is on left bearing cover of the slider shaft, to the rear of the flywheel. 4. In this position, the slot in the coupling on the governor shaft will be horizontal. This is equivalent to "No. 1 just fired!" Part 2 -- Magneto setup: 1. Obtain a spark plug. Wrap some uninsulated wire around the plug's base then connect it to the magneto's frame. Connect ignition lead between the upper terminal of the distributor cap and plug's input terminal. 2. Hold the magneto solidly in the same upright position as when mounted on the tractor. 3. Grip the driving lug on the impulse coupling firmly and turn the impulse slowly in a left-hand direction (counter-clockwise). Stop immediately when -- impulse trips and spark occurs at the plug. 4. When impulse trips, driving lugs on the impulse coupling will be in a horizontal position. This is equivalent to "No. 1 just fired." Part 3 -- Installing & Trimming Magneto 1. Replace magneto and gasket onto the governor case, making sure the impulse coupling lugs engage the slots on the governor drive coupling. A gasket must be used between the bolting flanges. 2. After tightening the two cap screws firmly with the fingers, rotate the top of the magneto toward the front of tractor as far as possible. Ensure both spark plug cables are disconnected from magneto! 3. Then rotate the flywheel one complete turn and align the flywheel mark "L.H. Impulse" exactly with the timing mark on the tractor. Do not pass the mark & come back to it! 4. Now, tap the top of the magneto toward the rear of the tractor a little at a time until the impulse trips. This is the right timing. 5. Tighten cap screws holding magneto to governor case. Then reinstall spark plugs and connect the spark plug cables. The flywheel side of the engine is the No. 1 cylinder. This spark plug cable (No. 1) must be installed in upper distributor cap terminal. Don't cross them up! ++++
