52 M Hydraulic Problem?
Jeff
10-26-1999 19:07:46
The oil level on my 52 JD "M" is way over full. At first I thought it might be gas or water in with the oil but after discussing the situation with a man who has a 40, he advised it may be the seal on my hydraulic pump leaking. Can this be and how difficult is it to replace? The tractor is on my farm which is about 200 miles from home, so I don't get much time to tinker with it. Any input appreciated.
Mike H
10-26-1999 19:55:00
 Re: 52 M Hydraulic Problem? in reply to Jeff, 10-26-1999 19:07:46
Yes this is a common problem.The pump is located on the right front of the engine right under the genarator is fairly simple to rebuild it will need the needle bearing along with the seal.And there is no gaskets between the pmup sections just use some kind of sealer your JD dealer can furnish the parts If not let me know
