Fuel gauge on 4520
Dwayne TX
08-12-2005 22:23:21
Took the advice I got when I posted the question earlier. The sending unit on the tank has one wire. I removed the wire and grounded it to the frame and the gauge needle went almost to the full mark. I pulled the sending unit out of the tank and worked the float manually with the wire still attached, but the needle didn't move. Is this a sure sign the sending unit is the problem?
Glen in TX
08-12-2005 22:33:49
 Re: Fuel gauge on 4520 in reply to Dwayne TX, 08-12-2005 22:23:21
If the sending unit was grounded while you did that yes its the sending unit. Can also hook a potentiometer to the wire and when you turn it if guage moves ok then you know wire and guage are ok. A sending unit is just a variable resistance switch like a potentiometer variable speed switch. Grounding the wire just completes the circuit like it would when sending unit is on full.
Dwayne TX
08-12-2005 22:41:57
 Re: Fuel gauge on 4520 in reply to Glen in TX, 08-12-2005 22:33:49
So, the sending unit is grounded when it's mounted to the tank? Do the mounting screws ground it or something else? It has the cork gasket.
msb
08-13-2005 07:53:13
 Re: Fuel gauge on 4520 in reply to Dwayne TX, 08-12-2005 22:41:57
It is grounded through the screws.The cork keeps it from leaking only.
