B rear wheels
Doug L
08-12-2005 21:43:35
I have a 1948 B and am having a terrible time getting the rear wheels off to replace tires. I removed the three bolts and tried to use the holes that pull the collar off, but get no where with that. Have stuck a large punch through the inside and tried to beat the collars off that way and they do no budge. Not a millimeter yet. Tried to use a jack to push them off to no avail. What"s next? I suppose I could cut the collars off. but then would have to find new ones and may do more damage to the hubs. Is this common or is there a secret?
Doug L
08-13-2005 19:19:44
 Re: B rear wheels in reply to Doug L, 08-12-2005 21:43:35
Thanks a bunch to all. I will try some more. I would replace on the tractor but also need to narrow the wheels. One way or the other they need to move.
Mike M
08-13-2005 12:49:54
If you can't get the bolts to push the collars off by screwing them in the threaded holes I would suspect that the bolt threads need cleaned good and a tap run into the holes to clean them out good. Once the threads are clean lube them good and try again as now they won't be binding in the holes and will have more pushing force.
DickD
08-13-2005 12:32:19
I have seen people put salt on the axles to hold the wheels, tin under the tapered locks and many more farm originated fixes. Sometimes they were a ---- to get loose. I used to loosen the bolts on the collar a little, and go to the field, watching closely for the wheel to move. When it did we would finish the job. Worked for us.
littleboyblue
08-13-2005 12:20:05
Heat up the wheel hub with a torch.... we do that when they have been on for a long while... it damages the paint but if it isnt show worthy then its fine to do..... and if u dont want to do that then it is a lot easier to change them with the rim on the tractor...just park on a hill.. with the tire u want to change on the lower side.. it makes for more stable jackage!!
JYD
08-13-2005 08:49:38
Doug,
Go to the Archives on this discussion forum (John Deere) and do a Keyword Search for "moving rear wheels". You will get a wealth of information to help you get your rear wheels/hubs free.
JYD
Mike@NY
08-13-2005 03:21:28
Form what I hear it is a common problem. I just bought a 43 B, and I got one side to move no problem, and the other side I spent a couple hours just trying to get the collar off. My neighbor's JD's all have the same issue with the rims being hard to move on the axle's. Another way to try and get the rim off, may be to remove the lugs that hold the centers to the hubs. Then again, mine is rusted on there just like the hubs, so that may or may not work. Ans all I am trying to do is narrow up the tractor. If you can, try what Harold suggested and change the tire with it on the tractor. People say it is easier (I have always take mine off). Good luck!
Mike@NY
HaroldIHC
08-12-2005 22:03:09
Just replaced the rear tires on my B with new ones. They are easyer to replace with the rims left on the tractor than off. ----Harold
