4020 #68020 SCV/breakaway
Tom/Idaho
08-12-2005 16:31:08
Is there a secret way to install new orings/backup teflon rings in the valve body? I am now on my third try. For some reason I keep slicing part of the teflon backup ring when I install the valves in the body. I use lots of grease and try to be gentle..... ..The valves are not scored and are smooth. The parts list I have show the orings on the inside and the teflon rings on the outside (the side closest to the open ends of the housing). Is this not right or would it make a difference?
I have resealed both breakaway valves and one on each side continues to drip oil. Any tips would be greatly appreciated cause it's the middle of the month and I already spent my beer allowance on this project.
Thanks, Tom/Idaho
matthies
08-12-2005 19:32:28
 Re: 4020 #68020 SCV/breakaway in reply to Tom/Idaho, 08-12-2005 16:31:08
Are you using an oring pick to spread the teflon ring once it's installed. What I do is take a 90 degree pick and push against the ends of the ring, this spreads the ring deeper in the housing. Once installed the tips of the ring should be right across from each other. I hope this makes sense. Also maybe your valves are worn some (O.D.) and causing your leaks. One more thing, take a hose with a guage and connect it to the leaking coupler and start the tractor. You might have pressure building from a leaking valve before the coupler. Just an idea. Are they leaking from the front or back and with or without a hose installed. chris
msb
08-12-2005 21:28:52
 Re: 4020 #68020 SCV/breakaway in reply to matthies, 08-12-2005 19:32:28
What are you installing first?The o rings or the back up washers?I find it is easier to install the o rings first and then do as Matthies says,use an o ring pick to gently spread the back up washer to where the beveled ends of the washers match up and overlap cleanly.The back up washers always go away from the pressure oil.In this case both the front and back washers go to the outsides of the break away coupler and the o rings toward the middle.
Tom/Idaho
08-13-2005 05:47:52
 Re: 4020 #68020 SCV/breakaway in reply to msb, 08-12-2005 21:28:52
Thanks for your responses. Both valves leak with the tractor running and nothing hooked up. They leak (drip is more like it)out the bottom where the lever is. I use an oring pick and install them like both of you suggested. The valve itself appears to be smooth. I will try to hook a hydraulic gauge up today it see if the problem is upstream.
Again, thanks for your help. Tom/Idaho
Pete/ME
08-15-2005 02:52:23
 Re: 4020 #68020 SCV/breakaway in reply to Tom/Idaho, 08-13-2005 05:47:52
Remotes leaked on my 2240, dealer rebuilt them twice and finally gave me the kit to try. They leaked again until I put the s.c.v. in the down position and kept it there...not a drip in two months...??? Shouldn't matter but it works.
Porter
08-13-2005 13:11:43
If they leak with no hose connected, then the coupler may need to be repaired. With nothing connected, the oil leaks around the levers, or around the barrels.
