404d
edward burleson
08-12-2005 14:31:00
I"m putting new sleeves in a 404 diesel engine
my john deere manual says to use john deere soap on the o-rings and sleeves. can i subsitute
with hand soap or silicone?
JDBert
08-15-2005 12:55:15
 Re: 404d in reply to edward burleson, 08-12-2005 14:31:00
We always use go-jo (you have to make sure its the original with NO pumice). This has always worked good for us, I've always been told that finger prints on a new sleeve can lead to "hot spots" on the sleeves as well as creating the possiblity for more corrosion, cant say thats true on the thicker sleeves, but it does make sense on some of the thin ones I've installed.
msb
08-12-2005 21:35:42
I would not use hand soap and definitely not use silicone.I have known some who used Go Jo hand cleaner with good success.I think most liquid detergents would be o.k. to use like Dawn or maybe Ivory ,but I would cut them with a very small amount of water.
G/MAN
08-12-2005 15:36:35
The nearest thing you'll find with similar lubricative properties is Murphy's Oil Soap. The thick stuff in a tub works real well. We used to use it all the time at the Cat dealership. The Deere 308 lubricating soap is a lot more liquid, and tends to dry pretty quickly. Make sure your o-ring grooves are very clean and give the o-rings and the bottom of the liner a nice coating of soap. Make sure your o-rings are in the right grooves - black on bottom, red on top and the square one at the top of the o-ring surface on the liner. Also, clamp them down securely when they're installed, as they tend to rise up out of the block until the head is on. I like to give the block a good look around the sleeves at the bottom to make sure there are no stray pieces of o-ring that got shaved off. I've probably installed a couple hundred liners in various engines, and haven't cut one yet, but I'm sure there will be that first time eventually.
Jerome grandi
02-17-2006 18:06:47
 Re: 404d in reply to G/MAN, 08-12-2005 15:36:35
I'm interested inputting an engine out of a John Deere 7700 combine in my John Deere 4430. I'm told this should work with changing the pan, maybe exhaust manifold? I'm wondering if the injection pump is the same? Someone told me that some of the combine motors do not have thrust bearings in the crank- will not operate properly with the clutch. Both have 404D motors.
