Leaky injectors
6030tom
08-11-2005 20:01:26
Cylinders 2,4,and 6 are all leaking and bubbling where they tighten down into the head. I have the correct injector wrench/socket - whatever it is - is there anyway to tighten them down with out removing the high pressure lines and the return line? They are the "Y" type injectors.
Thanks for any help.
G/MAN
08-12-2005 16:15:12
 Re: Leaky injectors in reply to 6030tom, 08-11-2005 20:01:26
It sounds like the nozzle bodies themselves may be leaking where they screw together below the nut holding them in the bores. Are these new, rebuilt or used nozzles? If they're leaking down there, they may be filling up that bore with fuel, which then pushes out around the threads of the retention nuts or between the nuts and nozzle bodies. Tightening the nozzles down tighter is not likely to cure this problem, and may in fact make it worse or lead to nozzle damage. Those nuts are only to be torqued to 55 lb.-ft. or so. I'd be all for pulling the nozzles. Clean them up well and use a nozzle tester (usually referred to as a pop-tester) to bring the internal pressure up to just a few hundred PSI below opening pressure and hold them there. You should be able to see where they're leaking fairly easily. And if you're dealing with old used units, you're also more than likely going to see low opening pressures, there maybe be a poor spray patter, and tip leakage is also a possibility. Left unchecked, the leaks are likely to get worse, and your tractor will thank you for the fuel-system attention with improved performance, power and fuel-economy. And a much cleaner engine.
msb
08-12-2005 07:49:36
The question is where are they leaking? Where the nozzles meet the head or is it the nozzles themselves.I would pull them out and have a look at the gasket on the bottom of the nozzles.If you see any carbon where the gaskets have leaked then clean the bores out real good and install new copper gaskets.Otherwise I would have the nozzles checked out by a good repair shop.Since you have the correct wrench,pulling the nozzles is not that big of a deal.I have an old milker inflation brush with the tip cut off that works real well to clean the bores with.
Bob
08-12-2005 08:38:25
 Re: Leaky injectors in reply to msb, 08-12-2005 07:49:36
Also, make sure there's only ONE copper gasket down there!
