taperlock on flywheel
7204411
08-11-2005 17:38:32
I was woundering if a taper lock is a addittion to an old worn fly wheel. Or if this is an new fly wheel of a new design.
7204411
08-13-2005 17:10:59
 Re: taperlock on flywheel in reply to 7204411, 08-11-2005 17:38:32
So I was wounding if you could have your crankshaft built up & then machined? But this sounds like what they come up with instead? About how much dose this cost? Have you done this?
Mike M
08-14-2005 05:57:41
 Re: taperlock on flywheel in reply to 7204411, 08-13-2005 17:10:59
If you had your crank built up it would involve pulling it out.Then you would still have wear in your flywheel and it would need replaced. This taperlock setup saves lots of labor and money.Not sure of the cost call Allen's and check it out.
7204411
08-14-2005 06:36:35
 Re: taperlock on flywheel in reply to Mike M, 08-14-2005 05:57:41
Thanks I will call and thanks again for your help. I take it you have set one of these up? I may be looking you up again to help get this one back to together! Thanks again! Ed
Mike M
08-14-2005 10:45:52
 Re: taperlock on flywheel in reply to 7204411, 08-14-2005 06:36:35
I have done several. Even bought just the center tapered sleeve once and machined the fylwheel myself to save some money.
Mike M
08-11-2005 18:02:43
It is both. You can have yours modified or buy a new one made heavier with it in. Best place to get one is Allen Machine in Tenn. try 423-753-5738
7204411
08-12-2005 19:37:48
 Re: taperlock on flywheel in reply to Mike M, 08-11-2005 18:02:43
May I get you toexplane the whole of taperlock. I have never seen one and have know idea how this works, just and image of something my imgination has come up with.
Mike M
08-13-2005 16:22:19
 Re: taperlock on flywheel in reply to 7204411, 08-12-2005 19:37:48
Have you ever used a collet in a lathe or mill ?
Pretty much works the same way. This setup is basically machineing your flywheel with a taper inside to accept a split collet that is tapered on the outside and splined inside to match your crank.It has a large nut on the outside that you tighten up drawing the tapered collet in makeing it squeeze tighter on the crank.
