A or B?
Bob Prinzivalli
08-11-2005 14:18:35
I was told I can go pick up an old tractor in a field. I will of course. It comes with a plow and harrow. It apears to be a 2 cylinder, 6 speed, "A" or "B" model from looking at what pictures I could find. It has the wide front end, and the battery is under the seat. Has been sitting about three years since it was run. Not much green paint left on it but mostly intact otherwise. How can I tell if it's an A or B? I could not find a data tag, but don't know where to look either.
Thanks for your help.
Bob Prinzivalli
08-12-2005 13:30:12
 Re: A or B? in reply to Bob Prinzivalli, 08-11-2005 14:18:35
IT'S A BOY!
Well actualy it's a "B" model. "Old" was correct in that if you look at many of the castings, transmission covers and things they all start with B. Also it is a seven slot grill. The ID tag is missing from under the magneto, but you can see where it was, so it may be a 1944 ish series seeings how they were steel in those years and rust a way. (So I've read.)One bad thing, the exhaust pipe is cracked near the flange, so the the motor may have gotten water in it. (I kind of hope so, so I have an excuse to overbore and fit new pistons and all.) Don't know yet. I will drag it home this weekend and start the surgery. Thanks to all for this great web site! I have many questions and know this is the place for answers.
Thanks again.
CLW
08-12-2005 16:35:45
 Re: A or B? in reply to Bob Prinzivalli, 08-12-2005 13:30:12
Bob, you said it has the batt. under the seat. If that is correct it is a 47-52. If it has round rear axles it is a 47-49. If it has square axles it is a late 49-52. The axles were changed at serial number 248257.
CLW
Pete/ME
08-12-2005 04:53:57
Just count the bars of the grill, six make it a B, and seven make it an A.
Bob Prinzivalli
08-12-2005 04:30:58
Thanks so much for the info. I'll go back today and look again. I did find some more usefull identification information here, >Link
I>Link did knock the hornets nests out of it yesterday so should get a better look today!
dan hill
08-13-2005 04:03:10
 Re: A or B? in reply to Bob Prinzivalli, 08-12-2005 04:30:58
Dont fool around, bring it home and fix it.
CLW
08-11-2005 20:06:07
Wes is mostly correct. I think he is thinking G rather than A on airstack and muffler. The grill on the B has 7 slots and the A has 8 on each side. If the muffler is correct on the A it will be in line with, and same size as the airstack. The B would be the same except the muffler will be smaller from the top of the airstack up and will be about 6 inches taller than the airstack.
CLW
Wes Miller
08-11-2005 18:20:10
if it is an "A" the exhust and intake stake shood be side by side if it is a "B" then they should be in line
also the "B" hase 7 grill slots where I believe the "A" hase 8
Mike M
08-11-2005 18:11:33
You should find a tag on top of the main engine case pretty much right under the Magneto,or dist.
Bob Prinzivalli
08-11-2005 15:58:44
 Re: A or B? in reply to old, 08-11-2005 14:34:19
I"m prety sure it"s a JD A or B according to the pictures I"ve seen. But the late 40 early 50"s A+B look alike. Thanks for the hint on the casting number prefix. Where would I find the number on the tractor?
old
08-11-2005 18:08:23
 Re: A or B? in reply to Bob Prinzivalli, 08-11-2005 15:58:44
All over the place most parts of it have casting numbers on them and most will have the A or B in the number.
