JD 4010 slow and weak hydraulics
RFox
08-11-2005 12:54:41
Hello, I have JD 4010 diesel that has slow and weak hydraulics. A retired mechanic checked the sump screen, hydraulic filter, and even changed the screen that is in the middle of the pump. He also said the priority valve is in good condition. He said the output psi at the remote bank is around 1,300, though in running it I would say less than that. He said it probably was in the main pressure pump up front. I don't think he did a charge test on the transmission pump, but he said he could usually tell if it was the transmission pump. The steering and brakes work great, 3 pt is slow and weak, no hyd leaks that I've seen. I'm about to just tear into it and swap out the main pump. Does that sound like the right thing to do? Are there any other tests a layman like myself could do to verify I'm on the right track?
Thanks Much everyone, R.Fox.
JDRocks
08-13-2005 06:15:26
 Re: JD 4010 slow and weak hydraulics in reply to RFox, 08-11-2005 12:54:41
What ever you do, be sure to use a guage that can go at least up to 3000 psi, better yet 5000 psi. You can find high pressure hydraulic guages at this site:
Link
gwece
08-12-2005 07:28:49
Sounds like the main pump is gone. Just went though the same thing with my 4010 last year. If you confirm the pump needs replacement, give me an email at [email protected] and I'll give you some tips on replacement and some pump puchase info. Let me assure you it is a pretty aggravating job to replace the main pump.
gwece
CMB
08-12-2005 06:56:49
My early 4010 started acting that way many yrs ago. Consulted my "Tractor Guru". He said the early ones had a relief valve that sometimes started to bypass back into the inner case, effectivly acting as a stroke control, & causing the pump to work hardly at all. Don't remember exactly what I did, but it was external,real simple & only took a few minutes to fix. It took MUCH longer to get the pressure back to a safe level, as I'd already "messed with" the stroke control. Had a hose running thru the seat frame,plugged into a rear outlet, with a 3000 psi guage between my legs. That guage pegged before the tach got to idle speed! I sure did some fast moves to shut it down before something blew! Seems like I adjusted it 3 or 4 times before I got back to 2250psi. As I understand it, the later tractors didn't have this relief valve at all, as it was later deemed unecessary.
RFox
08-12-2005 07:48:24
 Re: JD 4010 slow and weak hydraulics in reply to CMB, 08-12-2005 06:56:49
Thanks CMB - do you remember what area that relief valves was in?
CMB
08-12-2005 10:21:23
 Re: JD 4010 slow and weak hydraulics in reply to RFox, 08-12-2005 07:48:24
Boy!! It's been at least 20 yrs ago, but I THINK it was about the middle of the left side of the pump. Can't remember exactly what I did to fix it, but might have been as simple as installing a new needle, & possibly shimming up the spring to hold it in place to a higher pressure. I still have that 4010,& after lunch I'll go look & maybe have a better idea of just where it is. I would sure try all the simple things before I took the pump out. I don't remember that removing the pump is all that complicated a job, just a lot of work. In my experience the main pump very seldom wears completly out, but is USUALLY some part of the control system.
HTR
08-12-2005 09:32:32
The original 4010 pump had a thermal relief valve located on the side of the stroke control valve housing (that is the front cover of the pump). There was a service bulletin, that came out shortly after the tractors came out, to shim the relief valve solid so it could not function. I doubt that many of the 4010 pumps have survived forty five years, but if yours still has the valve, it is under a long cap nut, on the side of the front of the pump.
RFox
08-12-2005 09:56:23
 Re: JD 4010 slow and weak hydraulics in reply to HTR, 08-12-2005 09:32:32
Thanks, Interestingly enough, the mechanic said the pump is likely the original, so you guys might have pinpointed the problem. Would I be able to get to the valve without pulling the pump? And if so, what would be the best way to fix it if the valve is still there?
Thanks again!
CMB
08-12-2005 10:30:34
 Re: JD 4010 slow and weak hydraulics in reply to RFox, 08-12-2005 09:56:23
I believe HTR hit the nail on the head about the reliefe valve. Mine evidently never had the relief shimmed before I bought it in Dec of '67. Oh by the way, my pump IS the original,with 11000 hrs, still holds 2250 psi with almost no "quivering" of the needle on the test guage. It has had only a new seal kit, and a hole drilled & tapped to install a return line like the newer ones to keep pressure from the dust seal on the shaft.
RFox
08-12-2005 13:18:01
 Re: JD 4010 slow and weak hydraulics in reply to CMB, 08-12-2005 10:30:34
I think he may have too. You guys are Great! I will check into it this weekend. I'm not sure how many hours mine has, but if your tractor has 11,000 on the pump, then it probably is not my pump. Its true 'Nothing runs like a deere!'.
Thanks to all, RFox.
WTW
08-11-2005 14:04:48
If pump is quite and is not leaking I would have your retired mechanic swap out the stroke control valve in pump lid and set your pump pressure at 2250 to 2300 psi and that should fix your problem. Stroke control valve can be changed without removing the pump and will cause your problem if worn. Good Luck DW.
RFox
08-11-2005 14:09:06
 Re: JD 4010 slow and weak hydraulics in reply to WTW, 08-11-2005 14:04:48
Thanks for the info WTW! - Is the stroke control valve the one that is used to set the pressure?
WTW
08-12-2005 06:30:23
 Re: JD 4010 slow and weak hydraulics in reply to RFox, 08-11-2005 14:09:06
Yes it is. Remove the plugs above and below it to replace it, reassmble and adjust pressure. DW
RFox
08-21-2005 06:19:57
 Re: JD 4010 slow and weak hydraulics in reply to WTW, 08-12-2005 06:30:23
WTW - I think you were correct in advising to replace the stroke control valve. I replaced it yesterday, I don't have a gauge yet, so I've not tested it. But, I have some hope that it will resolve the low pressure problem, because on side of the valve and valve seat there was some pretty bad pitting, and the valve and seat had a ring worn fairly bad. I'll let you know if it does indeed fix the problem. But, based upon the old valve, I would think at a minimum it will at least improve the pressure.
Thanks for the advice!
