B , 50 520 Clutch the same??
Glen in TX
08-10-2005 21:53:37
Are some B, 50 and 520 clutch parts the same? Early 520 uses a B3760R clutch pulley, B3132R clutch collar and B3133R clutch fork. Are any of these the same on a B or 50? Thanks!
ChuckW
08-11-2005 11:02:36
 Re: B , 50 520 Clutch the same?? in reply to Glen in TX, 08-10-2005 21:53:37
The items I have on ebay has B clutch assy but 520/520 forks.....
ChuckW
08-11-2005 05:30:24
I looked on the JD parts and it appears B is different than 520/530 as everything was heavier on later model. The clutch linings are the same.
Glen in TX
08-11-2005 08:17:59
 Re: B , 50 520 Clutch the same?? in reply to ChuckW, 08-11-2005 05:30:24
Yes, Chuck. Someone sent me a B parts page of fork and it's all different so I guess the ones you have won't work. Some tell me a 530 clutch will work and some say it won't? I know there was a later style clutch fork for the late 520 and 530 but early 520 uses a different style and no one can tell me for sure if they will interchange. Thanks.
Mike M
08-11-2005 09:41:28
 Re: B , 50 520 Clutch the same?? in reply to Glen in TX, 08-11-2005 08:17:59
I think the later tractors like a 530 had a different set up on the fork that was adjustable. If you could get everything from a 530 it should all go on the 520,but I doubt the seperate pieces would fit.
Glen in TX
08-11-2005 09:51:10
 Re: B , 50 520 Clutch the same?? in reply to Mike M, 08-11-2005 09:41:28
That's what I'm wondering if all of it from a 530 with the adjustable fork would fit? At JD dealer the parts book shows different part numbers so I'm wondering if it will fit the cover and crank and clutch drive I have or not. This 520 is 5206xx. Thanks.
Mike M
08-11-2005 11:19:17
 Re: B , 50 520 Clutch the same?? in reply to Glen in TX, 08-11-2005 09:51:10
I was thinking some of those reduction covers are different too. Some have holes to access the adjustments. Maybe not on the 530 ? I might be thinking more of like a 720-730 ? Maybe if the fork had the posts for the adjustments and yours didn't you could just cut them off or leave the bolts out ? The rest of it should be close.
