JD 2355 4WD or JD2550 2WD
swanman
08-10-2005 20:53:46
I would like an opinion regarding purchasing either of the 2 models. The 2355 is a 1987 make, I don"t know the hours on it yet while the 2550 has about 1800 hours on it. Both have front end loaders. The 2550 has an enclosed cab. I live in the upper peninsula of MI and will be using the tractor for snow removal, moving round bales and general farm chores.
john e.c.MI
08-11-2005 05:48:14
 Re: JD 2355 4WD or JD2550 2WD in reply to swanman, 08-10-2005 20:53:46
The cab is nice, especially in the winter, but the MFWD makes a loader tractor. I have a 2555 with mfwd and a cab and it is a snow moving machine. A cab with air is nice but the air tends to fail on these older tractors in time.
PJBROWN
08-11-2005 05:15:07
A 2550 with only 1800 hours....that not even broken in yet :)hahahaha A 2550 is a great tractor.
buickanddeere
08-11-2005 01:53:54
Run a sample of the coolant, engine oil and trans oil. If they pass, purchase and enjoy the last of Deere's decent utility tractors. Before purchasing however. Swing past the Deere dealer and price a 5105 M4WD with loader. That will give you some pricing refernce. 18 years is enough time to accumulate some wear,tear and tinkering by the owner/operator. The cab does feel pretty good when moving snow.
timeforachevy
08-11-2005 05:17:51
 Re: JD 2355 4WD or JD2550 2WD in reply to buickanddeere, 08-11-2005 01:53:54
What do u mean by running a sample of the 3 fluids? Who would test them? what would they test for? How expensive are the tests? IS there any real advantage to these tests?
buickanddeere
08-11-2005 08:25:08
 Re: JD 2355 4WD or JD2550 2WD in reply to timeforachevy, 08-11-2005 05:17:51
Some owner/operators test the coolant and figure if it's good to -40F, its fine. Isn't so. Between heat, exposure to different hot metals in the presence of oxygen and carbon dioxide over time. The coolant will become acidic. Now between normal cavitation from diesel combustion shockwaves and corrosion. A wet sleeve engine will develop pinholes through the sleeve or the sleeve/block sealing surface. So saving money by not fully testing and changing coolant can be expensive. The engine oil needs to be checked for high wear rates or presence of coolant. The machine has to run a while, or fresh oil will fool the test. The common trans/hydraulic system Deere has been using it for 45 years. It still get toped up sometimes by illiterate geniuses who can't/won't read the owners manual. However they know everything and don't need to read the manual. Or being cheap they purchase the bargain hydraulic oil that isn't wet clutch compatible. So now the high/low clutches, PTO clutch and brakes friction material goes soft and flakes off. 1st the oil screen and filter gets plugged with friction material. Then with metal flakes after the friction material is gone. $$$ Mother Deere has oil test kits. So do most trucker supply depots and aircraft service facilities. Just check the phone book for the one nearest you. A 2355 M4WD will out work a 2550 on all but the firmest of soil or on pto loads.
