Did JD make a offset tractor like a Cub?
Willy P
08-10-2005 18:33:17
Did JD ever make one? A friend of mine has seen one and of course it is junked out and you guessed it the owner won't sell it,but he says that it is offset about a foot and it is a two cylinder with the spark plugs out the top and it has a mag and it has hydraulics,what model would this be? Has anyone ever seen one? He says that it looks like a Cub or a SuperA Farmall but it is a JD. Thanks
KenSWLA
08-12-2005 15:37:25
 Re: Did JD make a offset tractor like a Cub? in reply to Willy P, 08-10-2005 18:33:17
The M is slightly offset.
Henry J
08-11-2005 09:24:01
It appears that in general terms people think that the Dubuques are off set. I just don't understand how that can be, at least on my model, the W. One final drive will fit either side and the axels are listed as the same.
Would someone take the time to enlighten me pls.
Dan Hill
08-13-2005 04:15:42
 Re: Did JD make a offset tractor like a Cub? in reply to Henry J, 08-11-2005 09:24:01
Jd made the L and La about the same as the Cub, used a 2 cylinder Hercules engine.
johndeeregene
08-10-2005 21:25:22
i think all the duduque 2 cylinders were offset a few inches, the only true offset 2 cyolinder that i can think of is the 840 scaper or power unit what ever you want to call it.
tsmith1499
08-10-2005 21:09:24
I don't know about anyone else, but my LA seat is directly inline with the driveshaft, centered in the tractor frame. I don't see how that is offset. Tom
Deeredale
08-11-2005 14:10:10
 Re: Did JD make a offset tractor like a Cub? in reply to tsmith1499, 08-10-2005 21:09:24
On the L series everything was shifted left as you sit on the seat in order to give more sight down on the right. I think that is why originally they only had 1 front head light on the right side.
Mike M
08-11-2005 05:37:55
The seat is not offset ,but the engine was to help see around it better.
Deeredale
08-10-2005 18:44:09
The Ls were built offset. Not as much as the Cub but it as a little.
Newman
08-10-2005 18:58:01
 Re: Did JD make a offset tractor like a Cub? in reply to Deeredale, 08-10-2005 18:44:09
The one row 40 and 1010 were offset a few inches but not as much as a cub or 140.
hwarrior23
08-11-2005 05:25:20
 Re: Did JD make a offset tractor like a Cub? in reply to Newman, 08-10-2005 18:58:01
The m, 40s,420s,430s are all offset some. They are one row cultivating tractors with the "centerline" of the tractor along the right side of the frame/hood. John deere also made alater version in 1988,89 a 900HC with a 3 cylinder diesel.
