valve setting
bassndeere
08-10-2005 17:01:36
Hello,
Any secret procedures to setting valves on a 1948 JD D? Any help appreciated.
Thank you
Glen in TX
08-10-2005 17:26:25
 Re: valve setting in reply to bassndeere, 08-10-2005 17:01:36
No secrets if your camshaft is in time. Just rotate the flywheel until the LH Exhaust Open mark on flywheel lines up with mark on trans bearing cover towards the rear and all the tapper levers should be free. Loosen the clamp bolts on levers and turn the screw loose and then tighten back until no shake in levers and you can just barely spin the rod in your fingers. Then back off the screw a half turn and tighten the clamp bolts back. Rotate it a few turns and check again. Can run and check again later hot. I&T manual gives 0.030 gap for exhaust and inlet valves.
