John Deere D Clutch
B Duncan
08-10-2005 12:24:13
Hi group, I have begun to find out that it is a lot of work getting an old Deere running after it has set up a while. I have disassembled the clutch and am in the process of putting it back together after a through cleaning and new clutch discs. Is there any lube required on the toggles and dogs along with the sliding drive plate? If so what kind? Hopefully after this rebuild it will snap like a new one. Thanks in advance for all the help and advice
Brad D
buckeye al
08-10-2005 14:56:20
 Re: John Deere D Clutch in reply to B Duncan, 08-10-2005 12:24:13
I grease the toggles, the toggle sockets in the collar and both ends of the clutch dogs liberally with either a full or a synthetic blend wheel bearing grease. The wheel bearing grease being good for extreme pressures and temps both, is heavy bodied and therefore it stays in place. Have had very good luck and nice working clutches with it.
