620 Transmission Problem
Rodney P
10-26-1999 08:43:22
I am restoring a 620 that has been set up for
several years.
After I got it in the shop I went to put it in
gear and nothing would go.
The shifter will move freely up and down in the
neutral position but will not go left or right
into any gear. I am not very good with transmissions so if anyone can help please respond. Thanks
Steve
10-26-1999 14:19:05
 Re: 620 Transmission Problem in reply to Rodney P, 10-26-1999 08:43:22
The shift lever has come out of the shift rails due to wear. You will have to pull the shift quadrant off the top of the transmission and get the lever back in where it is supposed to be. You might want to examine all the parts for wear will you have it apart or it will do it again.
