? For Those Of Us With B's
MACE
08-10-2005 10:06:08
I have a 1950 B that I would like to put a 12 volt generator onto. When I mount the generator on the bracket, the pulley doesn"t line up. It is off by about a half inch. How do you guys get the pulley"s to line up on the B model john deere tractors. Or should I just convert a 6 volt generator to a 12 if possible?
Thankya,
MACE
Leroy
08-10-2005 17:09:53
 Re: ? For Those Of Us With B's in reply to MACE, 08-10-2005 10:06:08
I put a 12 volt generator on a 49 be from an old HC 145 G engine on a 45 combine, the only thing to mount I had to use the tightner strap from the combine generator with the tractor strap bolting them together. also used the regulator from same combine along with coil from same machine. only thing you have to be running at over half throttle to charge
RayP(MI)
08-10-2005 17:06:55
My generator shop fixed me up with a 12v regulator on existing generator. Works OK -only way you can see that it's 12v is to look at the battery.
buckeye al
08-10-2005 15:02:11
It's been a long time since I bought my last B but as I recall it had a belt alignment problem when I bought it & I believe all I had to do was flip the pulley to fix it. Seems some tractors had the long reach of the pulley forward, some had it back. Either that or the last guy to monkey with it just put it together backward. I was and stayed 6 volt however.
Good luck.
Mike M
08-10-2005 10:07:58
That lower bracket should have some adjustment in it if not enough slot the holes some more.
MACE
08-10-2005 12:39:38
 Re: ? For Those Of Us With B's in reply to Mike M, 08-10-2005 10:07:58
Thanks for the advice and quick reply!
MACE
