50,60,70 hitch
billonthefarm
08-10-2005 09:22:25
I was wondering if anyone has some info on the capacities of the 800 series hitches on early number series tractors? I cant find anywhere in any literature where it gives a approximate lift capacity. Thanks for the help!
CMB
08-11-2005 07:55:27
 Re: 50,60,70 hitch in reply to billonthefarm, 08-10-2005 09:22:25
In the 1960's I had a "G" that was bored .125 over with aluminum pistons & a "cold" manifold(Turned 50+ hp). I used it with an 800A hitch, & a 15 1/2 ft "C10" field cult. Had to put 500 lbs out front to keep it stable (well almost!) Always wondered if I was "flirting with disaster" with that outfit, but never had any problems at all. Always ran in 3rd gear, & sometimes pulled a 16ft cultipacker behind.(not in hilly terrain though). Used it this way for several yrs. without any breakage, until I bought a 4010D to replace the "G". (Sure wish I hadn't sold that hitch!)
G/MAN
08-11-2005 07:38:46
I don't have any lift specs either, but the main thing you want to remember is that you're not dealing with a single rockshaft. You're dealing with two separate rockshafts that are connected together, and that's not as strong as a continuous shaft all the way across. You're also dealing with 50-year-old components that have been subjected to who knows what stress in the past.
How about
08-10-2005 19:34:50
Would it pick up say a 1800 lbs round bale and if it would how much counter weight does it take?
Superpicker
08-10-2005 15:31:40
I had a a cousin with a 70D that broke the rockshaft using a 3pt. too heavy 6 row cultivator.
kevin l
08-10-2005 11:05:22
some of the info is whether it's catagory 1 or catagory 2 type hitch can help determine capacity,
think that has more to do with pulling not lifting and think the 800 are cat 1. the break down prssure is about 900 psi and the same on the hyd. for the 50 60 & 70. so it's more of a balancing act or center of gravity, the longer out the back the more weight up front.
Mike M
08-10-2005 12:18:00
 Re: 50,60,70 hitch in reply to kevin l, 08-10-2005 11:05:22
The 800 series hitches are cat 2 .
Mike M
08-10-2005 10:14:25
I can't say as I have saw anything either,but if used on the right tractors and the hyd. pressure is set where it is to be it should handle all the tractor can dish out. How heavy is a 4 bottom mtd. plow ? I would think a 70 could handle that.
