John Deere B starting problem
Jon Dory
08-09-2005 19:08:39
I recently transported a 1947 John Deere B from Iowa to Colorado. The tractor ran very well in Ia thanks to a relative's willingness to work on it. However, as I attempted to unload it in Colorado I found it would not start. I suspect it needs to be "leaned-out" as the air is thinner at 5200 ft. How does one accomplish this? Or are there any other issues? It certainly is getting fuel and spark. Smells a little flooded...
JD Jones
08-09-2005 20:05:19
 Re: John Deere B starting problem in reply to Jon Dory, 08-09-2005 19:08:39
jon this is a pretty easy task. all you must do is screw in the needle jets located on top of the carb until the tractor smooths out. this may not be the problem though. through transporting something could have got under the needle and seat and cause the gas to overflow in the carb. therefore flooding the tractor. sometimes tapping on the bowl will fix it, sometimes you have to pull the bowl down and clean out the needle and seat .
hope this helps
Lonzo
08-10-2005 08:28:19
 Re: John Deere B starting problem in reply to JD Jones, 08-09-2005 20:05:19
take plugs out, crank enging 3-4 times, install new plugs, and start.
Dan Hill
08-13-2005 04:38:21
 Re: John Deere B starting problem in reply to Lonzo, 08-10-2005 08:28:19
You may have a weak spark.OLd magnetos get tired,Points, condenser and coil are usual problems.Stale gas will give much trouble, try a little prestone starting fluid.Old JDs dont like over choking either
