2630 fuel leak
Curt33
08-09-2005 18:26:13
I hope everyone will ignore my ignorance, but I don"t know squat about a diesle engine. Also, my wife lost my repair manual and I don"t even know what to call what I"m talking about.
On my 2630 there is a return fuel line that enters at the top of the fuel tank. Follow it back towards the engine a bit and it becomes a fragmented metal line with short sections of hose in between, and the line at 4 points is attached to something I don"t even know what it is, but they sit above the injectors. At any rate, for no apparent reason while bush-hogging fuel started spurting out of one of the runbber line sections where it pushes up onto the metal part. The previous owner had put 2 clamps at 2 other unions, so I did the same at my leaking site, which then caused the leak to move on to the next rubber/metal union. I put clamps on all the unions, started tractor, and now under any kind of load or high throttle operation, the tractor dies. The clamps did not as far as I can see stop fuel flow. Anyone have a clue as to what might be wrong? I am sorry for the lack of better descriptive terms, but when I order a new manual my next post will hopefully make more sense. I appreciate any and all help anyone can give me. Curt
podunkpapa
08-24-2005 18:55:11
 Re: 2630 fuel leak my 1020 is doing the same thing in reply to Curt33, 08-09-2005 18:26:13
My 1020 is doing the same thing. I have blown out the line, took the tee"s off the injectors and cleaned them out, replaced the rubber line, replaced the gas cap to make sure it is venting. When I took the tee"s off and blew the center on out there was some reddish-brown crystal-like stuff in it. It ran good for an hour or two and then I had to blow out the middle one again. Found the same stuff in it. What is this stuff and where is it coming from? I have a new fuel filter. My return line does not have any clamps on it, should it?
Tx Jim
08-10-2005 03:44:06
 return line plugged in reply to Curt33, 08-09-2005 18:26:13
Curt,your return line may be plugged.This will stop return flow back to tank causing engine to die.I think the # for rubber boots is T20055 but it's been along time since I stood behind parts counter.Jim
Tx Jim
08-10-2005 15:41:09
 wrong # in reply to Tx Jim, 08-10-2005 03:44:06
CRS is terrible to have
msb
08-09-2005 19:58:08
 Re: 2630 fuel leak in reply to Curt33, 08-09-2005 18:26:13
They are called injector return line boots.The simple answer is to replace them all.They get brittle after a few years and crack.Use the original spring wire clamps on them.
