2020 Rear End HELP PLEEEASE
Vicky Mendoza
08-09-2005 17:13:46
We are needing guidence on how to change the fluide in the rear end ,it has water in it.We can't find the owners manual.We inherited it and we are new to all this. Please tell us how to change it, and what type of fluid to put back in it. Thanks.
Vicky
[email protected]
mitchp
08-10-2005 06:30:27
 Re: 2020 Rear End HELP PLEEEASE in reply to Vicky Mendoza, 08-09-2005 17:13:46
hey vicky, just to add to jim's responce, you'll need to replace the gaskets when you remove the filter, i believe there is two of them, deere doesn't include them in the filter, you have to get them seperate (which is dumb) This is important, i learned the hard way, i didn't do it, started the tractor and fluid went everywhere, i mean gallons of it, come to find out the gasket had broke. Also check your gearshift boots, they will dry crack and water can get in that way, you might want to replace those as well, easy to do too.
Vicky Mendoza
08-10-2005 08:29:12
 Re: 2020 Rear End HELP PLEEEASE in reply to mitchp, 08-10-2005 06:30:27
You guys are Great !!!!! !! We will be out in the 100 degree sun this afternoon looking for that plug. Hope we get it done.LOve ya guys for the info. Hubby thinks I am so smart finding all this stuff out for him on internet,(and it makes him look smarter to, so he doesn't have to take it to dealer)! :) I am glad I found this board we also have a 3020.
Thanks again
Vicky
MITCHP
08-11-2005 07:47:00
 Re: 2020 Rear End HELP PLEEEASE in reply to Vicky Mendoza, 08-10-2005 08:29:12
LET US KNOW HOW IT GOES
Tx Jim
08-10-2005 03:50:52
Vicky,there is a plug in bottom of transmission under seat.You also need to change hyd. filter which is located under floorboard on RH side.Transmission and differential are together and hold about 8 gals.JD recommends Hy-gard oil.Type of oil is important because brakes run in oil. Tx Jim
Vicky Mendoza
08-10-2005 08:30:55
 Re: 2020 Rear End HELP PLEEEASE in reply to Tx Jim, 08-10-2005 03:50:52
You guys are Great !!!! We will be out in the 100 degree sun this afternoon looking for that plug. Hope we get it done.LOve ya guys for the info. Hubby thinks I am so smart finding all this stuff out for him on internet,(and it makes him look smarter to, so he doesn't have to take it to dealer)! :) I am glad I found this board we also have a 3020.
Thanks again
Vicky
