820 diesel oil pressure
JD49A
08-09-2005 16:50:27
I have a greendash 820 diesel that when I go up a hill I lose oil pressure but on the flat it returns to normal. I have check the dipstick and it is up to the full mark. I have put a master gauge on to and it shows a drop in oil pressure too. So I know that it"s not my gauge. What eles could it be?
Thanks, Matt
kevin l
08-10-2005 11:10:23
 Re: 820 diesel oil pressure in reply to JD49A, 08-09-2005 16:50:27
part of the pickup tube is missing or broken off or a crack in the tube or screen part.
F-I-T
08-10-2005 14:20:37
 Re: 820 diesel oil pressure in reply to kevin l, 08-10-2005 11:10:23
I'm not so sure about that. There is no pick up tube to break on a Waterloo pump. The pump unit mounts in the bottom of the crankcase, has only an output tube, and has an integral screen. To top that off, the whole shebang sits in several inches of oil at all times.
I'd be more inclined to look for something like a piece of gasket or a corn leaf in the crankcase that might be flopping up against the screen when the attitude of the pump is changed. That is a really big stretch, but I have to say, this is first for me, hearing of this condition.
Maybe there is something interfering with the by-pass valve? If it were me, I would turn the pressure adjusting screw in, and see if the presure goes up as it should. If not, or if it will go no further, then turn it out briefly to possibly let any dirt trapped there to blow on by, then re-adjust it to the pressure you need.
After that, it sounds like you might want to drop the pump and have a look, or as I would prefer, go in through the top after slowly draining the oil to see if there is some debris getting in the way of things.
It would be a grea time to have a borescope and enter through the dip stick hole.
You know any proctologists? :)
Frank
JD Jones
08-09-2005 20:07:34
Matt it sounds like you could have a blockage in the oil pump pickup. you can pull it down. there are 3 bolts i believe and clean out the screen. maybe the back side is blocked and when you go uphill it starves the pump. hope this helps
