620 sometimes moves, sometimes doesn't
JD 4020 3020 62
08-08-2005 20:28:21
My 620 has had this problem for a while and seems to be getting worse. Sometimes when you shift gears and put it in 1,2, 4 or Reverse there is no movement with the clutch engaged. To get the gears back you have to put it in 3,5 or 6 and engage the clutch. Also sometimes when shifting out of some gears especially reverse and 4th you will hear a loud ping, which sounds like something hits the tin cover in front of the left hand brake. I have no idea whats the cause or where to look as I haven't taken anything apart or have done much repair on a 2 cylinder.
bigburley
08-10-2005 20:54:17
 Re: 620 sometimes moves, sometimes doesn't in reply to JD 4020 3020 620 420, 08-08-2005 20:28:21
The end of the gear shift has a ball in it. The ball fits in the shifter rail. Over time the ball wears a pocket in the shifter rail then it changes the amount of movement the shifter rail. I have taken the gear shift cover off and welded those pockets back to original. If you overweld use a die grinder with a stone on it and grind off the excess weld.
PeterE
08-09-2005 12:14:23
I'm not familiar with the 620, but my late styled B has a similar problem. On the B, there are three gears going up on the right side of the pattern, and three going up on the left side. You can only move from the right to left side down in neutral. When moving from the right to left, the fingers to engage the gears can be missed, so it has to be moved back down there to catch them. If that makes any sense.
I don't know if the 620 transmission is the same way, but it sounds similar.
