1935 A only running on one
kirby
08-08-2005 20:25:18
I have a 1935 A that is only running on one. i had just did a head job on this tractor and a new manfold. i have spark at both plugs but it is only runing on one. the only thing i have not gone through is the carb. would like help with ideas.
John T
08-09-2005 05:55:42
 Re: 1935 A only running on one in reply to kirby , 08-08-2005 20:25:18
Kikrby, since that tractor has a single barell carb that serves BOTH cylinders, I dont see it as the problem. I guess you are aware that at idle the left cylinder fires MUCH stronger then the right?? If you pull the left plug wire she almost dies, while pulling the right dont make that much difference. Thats due to the fact the left gets a better charge of gas due to the 0 (left) then 180 (right) firing sequence with the long 540 degree coast cycle in which residual gas and vacuum in the manifold allows for a good gas charge when the left side sucks in gas n air.
Of course, this assumes BOTH plugs are firing equal. If she fires stronger on one side then the other, look for a cap or rotor or plug wire or plug difference. You could swap plugs n wires to isolate any bad wire or plug.
To be safe you might check compression on both sides to see if one is higher??? check the valve lash setings also.
John T
