14T baler
Ron SD
08-08-2005 19:28:41
I have a 14t baler that is not tieing on one side. The twine that comes up from the needle has a knot. The other twine is inside this knot but pulls through. Any ideas. Thanks Ron
John T
08-09-2005 06:00:37
 Re: 14T baler in reply to Ron SD, 08-08-2005 19:28:41
Ron its been way too long since I ran a 14, so take this with a grain of salt. I would have a friend rotate the flywheel and you trip the knotters and observe whats happening. Things that come to mind are too loose billhook tension and check the twine feed and tension on that bad side. Make sure the tucker fingers are swinging back on that bad side also and spring return as they should.
Sorry not much help on this one not being there.
John T
