Fuel tank stick
Dave in SV
08-08-2005 19:24:55
I have a stick for checking fuel level in my '26 Ford Model T car. Is there such a thing for my '49 JD A Model? I understand that the tank holds 14 gallons, but I don't know how to guage how much I have at a given time other than to look down the fiiler neck and guess. I can make a stick with graduation marks on it if there isn't something authentic/original out there.
No, guys, I won't use a match for more light when I look down the filler neck!
Mike M
08-09-2005 08:01:34
 Re: Fuel tank stick in reply to Dave in SV, 08-08-2005 19:24:55
I have seen some with a cap with a gauge on it more than likely aftermarket.
weedsabate
08-08-2005 20:38:55
Dave, I'm not aware of any aftermarket sticks. I made my own. In your case if your sure that it holds 14 gal. I would probably start with an empty tank, put in one gal. and mark the stick, one more gal. and mark.same until 4 gal. then dump in 5 mark, and obviously the remaing 5 will bring it to 14... the bottom gals are what you are conserned about. just my .02 Jerry
Dave in SV
08-09-2005 04:14:59
 Re: Fuel tank stick in reply to weedsabate, 08-08-2005 20:38:55
Yep, that was my plan, too. I'm basing the "fact" that the tank holds 14 gallons on what is written in paragraph 2, page 16, of the OMR2001 Operator's Manual... guess I'll know for sure once I follow the process you outlined.
Thanks.
