JD 2355
Larry Otis
08-08-2005 18:25:30
I am looking at a JD 2355 4wd w/ cab. Can anyone tell me pros and cons of this tractor? Any good for mounting a loader to? Do they have much power? Thanks, Larry
buickanddeere
08-09-2005 05:26:56
 Re: JD 2355 in reply to Larry Otis, 08-08-2005 18:25:30
Who isn't looking for a M4WD 2155,2355,2555? They are better than the p.o.s. 5000, 5000 ten, 5000 twenty and maybe even the 5000 twenty five replacements.
730-LP
08-08-2005 20:12:03
I have two 2355's one is 2 wheel and open station the other is 4 wheel drive with a cab.Both tractors are rated at 55hp but shows 68hp on the dyno the 4wheel drive has a 245 loader and will pick up and handle 3000lb with pallet forks real well.It will pick up more but get's a little lite in the rear both tractors have around 4000hrs and have never had any major repairs.You will find the 3&4 reverse a little fast on it. In my opinion "everone has one" the 55 series are the best handling tractors deere built.
larry otis
08-09-2005 04:38:34
 Re: JD 2355 in reply to 730-LP, 08-08-2005 20:12:03
Does the 4 wheel drive have a turbo? or can one be added? I was a bit concerned that the tractor was only 55hp. Does the 245 loader clear the front wheels with fenders? Joystick control insid the cab, correct? Have you done any major work on either? Are they easy to work on? The 2355 I am looking at is in very rough shape and will need a great deal of TLC, but is something I would like to work on as a project tractor. Thanks again, Larry
730-LP
08-10-2005 11:08:27
 Re: JD 2355 in reply to larry otis, 08-09-2005 04:38:34
A 2355 doesn't have a turbo.You can have one installed and have the same engine as a 2555,The 245 or 640 loader will work fine with fenders .The tractor will be as easy to work on as most any other tractor of the same year model.
