4440 brake job
jd jim A
08-08-2005 15:48:48
Trying to replace the brakes on a 4440. Started with the left side, everything went fine. Got the right side back together, and found that I cannot turn the right wheel, even with the transmission in nuetral and the tow disconnect back (it's a powershift). Whats going on here? Everything slid right back together, even easier than the left side. I installed the small disk onto the sun gear, installed the sun gear into the differential, set the large outer disk on the sun gear, as I hoisted the wheel/axle assembly into position, I clearly felt the sun gear start into the planetary. I then lifted the large outer disk onto the small dowel pins in the axle housing with a small pry bar. As soon as I had the axle housing started onto the large dowel pins, I drew it up with two bolts, slid right together. The left wheel turns right over by hand.
Tom (Ks)
08-08-2005 20:37:21
 Re: 4440 brake job in reply to jd jim A, 08-08-2005 15:48:48
Some of the replacement disks are thicker than your old ones, loosen your final drive bolts just a little and see if you can turn the axle over. If you can, then you can add one extra gasket on the right side and it should turn. I've had to double up on the gaskets on 4640's, 6030's and others. A few times when I would swap finals from side to side, I had to leave the brakes alone in order for them to clear.
Nylon
08-09-2005 21:45:17
 Re: 4440 brake job in reply to Tom (Ks), 08-08-2005 20:37:21
Have you had this trouble with 4020s 68 synchro? Would it be smart to order extra gaskets for both sides to have on hand?
Thanks,
John
jd jim A.
08-09-2005 16:07:59
well, you were right. Got the correct disk and it works.
