730d pto brake adjustment
jdjack
08-08-2005 07:43:05
I just put in new seals on pto pump(was leaking trans fluid in pto housing) new brake disc and 11 new facings. When tracot is runnind and pedal is pushed down it still turns. I got it adjusted so if the pedal is latched in bottom groove it will stop. My question when should it stop? only when it is detent of latch, or should it stop moving when pedal is moved half way or more to disengaged.
CFWelles
08-08-2005 19:44:54
 Re: 730d pto brake adjustment in reply to jdjack, 08-08-2005 07:43:05
Did you get the engage and then the disengage position on the clutch set so that the indicator pin shows one land of movement between the two positions? This, I believe, determines the correct amount of tensioning and then proper release so the brake doesn't attempt to fight the clutches (it would lose). IF this is set to spec, then you can move the pedal all the way back to the detent and keep turning the threaded yoke a half turn at the time until the pto stops. I don't think they will ever stop without the brake. I just finished rebuilding my 730D also and went through this procedure which is outlined in the service manual. The procedure for engagement adjustment using the indicator pin is in the owners manual as well.
MSM
08-08-2005 14:42:29
If the pto stops when latched,and doesn't lug the engine when in this position it is most probably adjusted correctly. The pto will spin when not in the detent(brake position) due in part to the new clutches,and it is running in oil which will tend to make it spin.
