Breaking in a re-built engine -
JGC
08-07-2005 18:04:50
The tractor is an unstyled "D". I have completely re-built the engine and transmission. This tractor has not been put to work.
I am taking it to a show this weekend. They will have a tractor pull there. I'm thinking I can carefully pull it a few times.
It won't be competitive since the tires aren't loaded and the wheel weights aren't installed. Please advise how to pull for the first time.
Thanks,
Jon
MITCHP
08-09-2005 12:00:07
 Re: Breaking in a re-built engine - in reply to JGC, 08-07-2005 18:04:50
LIKE AN OLD GUY TOLD ME TO DO AFTER HE REBUILT THE MOTOR IN MY 8N FORD "TAKE IT OUT AND WORK THE HECK OUT OF IT" YOU DEFENTLY WANT TO GET THE RINGS SEATED GOOD SO A GOOD LONG WORK WILL DO IT A WORLD OF GOOD, MINE SURE GOT ONE WITH BUSH HOGGING AND HAS BEEN GREAT SINCE.
F-I-T
08-08-2005 08:42:04
I think I would rather see you find a Baker fan at the show and give it a chance to break-in under a nice consistent load.
I am also a fan of the John Deere Break-in oil. It sure looks thin, but it really does the job.
Getting the tractor up to temperature and then loading properly for probably 30 minutes or an hour, is whole lot different than running it down the track from a standing start to less than half load if you baby it, for what? 45 seconds? I don't that will break it in at all. I don't necessarily think it will hurt it either, but a few shots down the track isn't going to make much of a difference on breaking it in versus putting around the yard.
Try to find a Prony break or a fan to belt it to, or find a big old log to drag around, moving up a gear at a time as it gets warmer.
Frank
G/MAN
08-08-2005 07:14:08
I agree with the others - work it fairly hard but keep an eye on things. You definitely don't want to baby it or idle it excessively. Today's motor oils are getting so good with their anti-wear additives that breaking in a engine with them can be difficult. That's why Deere came up with their Break-In oil for their engines - lower viscosity at 10W30, and with fewer anti-wear additives in order to promote ring seating. They pretty much guarantee you that if you fill a new engine or new rebuild with their Plus 50 oil that you won't be able to get it broken in properly.
txgrn
08-08-2005 04:56:32
Sounds like a pretty good workout for a new rebuild. Normally one recommends "working" the tractor to set the rings. Looks like yours is going to be worked.
Only thing I can say is watch the temp. Since things are new, there's a lot of internal friction which generates heat. You want to work it but don't want to overheat it. Just keep your eyeballs on the temp gauge and if she gets up around 200, idle her down and let her cool.....then go again. Also before shutting her down, give her time to cool off. Simple as that.....and I agree with msb, get her warmed up before you smack her.
Mark
msb
08-07-2005 20:49:41
Just be sure the water temp is up to normal.90% of engine wear occurs in the first few minutes before the temperature comes up to normal.
