'47 D low oil pressure
Mark Scholten
08-07-2005 17:55:16
Where do I start looking for a low oil pressure problem? Is there an adjustment? I am going to pull the gear pump cover off and regasket it and this may improve the pressure but it runs just below the red line all the time so I don't think I can boost it much with a thinner gasket.
Thanks in advance, Mark
Glen in TX
08-08-2005 07:44:01
 Re: '47 D low oil pressure in reply to Mark Scholten, 08-07-2005 17:55:16
Mark, Something else I didn't mention earlier is that the oil filter can body could be distorted from overtightening of the filter nut on bottom. This can cause little or no oil pressure and the lines, filter block, and can have to be removed so the can is resealed next to the casting. Best to find a better one to replace it with if possible. It shows and explains this in the I&T JD-4 shop manual that covers JD A,B,D,G,H,M & MT tractors. It shows how to make removal and install tools to do this. If you need more info email me. Glen
Glen in TX
08-07-2005 20:54:29
Mark, Inside the motor under the crankcase cover on top of the oil filter can you will see the regulator body with all the oil lines connected to it. There is shield to take off and under it is a 3/8" bolt that needs to be loosened and then you can turn the adjusting screw in to increase pressure or out to decrease. Make sure your lines are ok and not plugged or that one is leaking too much. The line under the governor is hard to see and sometimes it breaks off or the jet on top is missing. Yes, you have to take the crankcase cover over and more to get to it. You may want make sure the bearings are oiling good while in there and shim the bearings some too if needed if that hasn't been done in a while.
