Clutch jumps out
Ben48A
08-07-2005 16:50:56
I have a 1948 A and when I'm going I have to push on the bottem of the clutch lever with my foot to keep it in. Otherwise the clutch lever falls back and starts bouncing until it bounces hard enough to knock it out. I re bushed most of the parts except the top of the acutal clutch. Is it just to sloppy of what?
Mike M
08-07-2005 17:49:12
 Re: Clutch jumps out in reply to Ben48A, 08-07-2005 16:50:56
Does your clutch SNAP in ? I think the book says to have 70-80 lbs pull on the end of the lever.
Ben48A
08-08-2005 17:05:10
 Re: Clutch jumps out in reply to Mike M, 08-07-2005 17:49:12
It snaps disengaguing but it just sort of pushes in going in.
Soldier Tom
08-08-2005 17:59:08
 Re: Clutch jumps out in reply to Ben48A, 08-08-2005 17:05:10
My 720D'sel did the same thing. We started in the clutch, and put new sleeve in it, dogs, toggles, and bolts. New clutch disks and floating disks. Then re-bushed it all and bored the holes larger and put in bigger pins, and a new clutch lever bolt; behind the flywheel we replaced the (missing) thrust washers. THEN tightened it all up like it said to in the book.
Crisp snap in, hard tug to unsnap. Still adjusting along a little after every few hours to get it just right. But, until you stop that slop, it will just fall out, best you can do.
~Walk in peace~
Soldier Tom
Mike M
08-08-2005 17:57:14
It should snap both ways ? I'd tear it apart and check the facings and also see if they are in proper order. I'd also clean and repack the bearing and clean the pulley where the adjustment bolts go through the holes and clean and regrease the toggles and dogs. Sometimes a good cleaning will free them up.Keep a look out for cracked parts.
F-I-T
08-08-2005 18:21:04
 Re: Clutch jumps out in reply to Mike M, 08-08-2005 17:57:14
On a '48, since it is just a two facing clutch (one in front of the driving disk, and one behind it), it's doubtful there are any parts in there incorrectly, but it's always good to check. Like you say, sometimes if you just clean everything well, wire brush the threads, and look for wear notches formed on the three pull-in bolts. Sometimes a ridge there can keep it from fully engaging and giving the "Snap'.
Frank
