54 model 40U
david r meyer
08-07-2005 13:51:54
Hey I hope someone can help me on this, I'm not getting spark at all, I have power all the way to the distributer it's snapping over, could this be a bad condenser? I want to try the easiest things first, also the switch up by the driver has off, I, L, D. B, I'm guessing I is for ignition and L for lights but what about the rest, Thanks
Ray
08-07-2005 17:42:44
 Re: 54 model 40U in reply to david r meyer, 08-07-2005 13:51:54
File the points,they sometimes corrode,install
the coil wire in the coil,hold the other end near
the block or some other ground and flip the points.(with ignition on).You should see a spark
jump if everything is working.
JYD
08-07-2005 16:11:58
David,
"I" - ignition only
"L" - ignition, bright front lights, white rear light
"B" - ignition, bright front lights, red rear light
"D" - ignition, dim front lights, red rear light
JYD
david r meyer
08-07-2005 18:12:03
 Re: 54 model 40U in reply to JYD, 08-07-2005 16:11:58
Thanks alot
