B kicks out of 3rd gear
jd b puller
08-07-2005 05:09:22
Hey all. I need some help.
1947 JD B. Single 6 speed. Good HP.
Ok, so I went to a pull this weekend. I was pulling in 3rd gear and when it started pulling harder all the sudden the tractor just quit moving. The engine was still running. I looked down and the gear shift lever was right there in 3rd gear (Grandads used to pop out of 3rd but it would physically move the lever when plowing). I popped the clutch and put in 4th and drove off, dissapointed. My only thought is that the HI/LO kicked out, but how do I keep it from doing this, I really liked pulling in 3rd.
Ben48A
08-07-2005 16:37:03
 Re: B kicks out of 3rd gear in reply to jd b puller, 08-07-2005 05:09:22
I think it's a detent ball in the hi/lo selecter. When you shift form some hi range gear to reverse it doesn't always stay in on my A. Sometimes I have to play with the lever. All you should have to do it take the tranissmition cover off and put a new detent ball in.
