D Radiator
Wes
08-06-2005 20:14:05
I have a leak in the bottom of the tank. Just a fine crack that weeps a little antifreeze . I have never removed one this size. What does it weight? I think that a engine hoist(cherry picker) would pick it up. I think that the crack can be welded without taking the radiator apart. The crack is in the middle of a long flat space. I was able to get the gaskets for the bottom on each side where it bolts onto the head. But I have not been able to find one for the the top where the 3 bolts are. What do you recommend for using to seal where the gasket goes?
Thanks
Wes
Glen in TX
08-07-2005 10:10:04
 Re: D Radiator in reply to Wes, 08-06-2005 20:14:05
Wes, I did some looking today and have the upper and lower water pipe gaskets or you can probably get some fresher ones from Greg. Didn't have any good lower radiator tanks though. Like Bob said we have welded those before too and blast cleaned them and then brazed the crack. If lots of small cracks shooting out drill a small hole at the end of the crack before welding. A good welder can heli-arc it with some cast rod too. If you aren't a welder clean it real well and use the regular JB weld and not the quick set kind and let it cure over 24 hours. The gasket sealer I was thinking of before is black in a cheese whiz type can and call "Great Stuff". Permatex works good too.
Bob-Wyo
08-07-2005 08:33:47
Wes as Glen said they are heavy,aprox 200# my guess, my buddy and I have put them on and off by hand and it's a load for each, best to use a hoist of some kind, then you won't pay for it down the old age road. David you need to find another welder, sure it's thin, but don't mean it can't be welded, just have to go at it much slower, right rod, heat range and never let it get to hot to touch.I had one that had a 19" crack all the way across the front flat part and have it welded up, no leaks and you can't tell it was welded, and I'm miles away form being a pro welder and half blind. Glen has you going on gaskets, but I just bought one not to long ago from Deere. Use Permatex #2, light coat on metal parts and let cure, when you are ready to put it together give all parts another light coat about 30 min before installing, great stuff, Clooney put me on to it, also gaskets don't slide out of place either.
Good luck with your D,
Bob
David from Kansas
08-07-2005 07:46:38
Wes,
I had the same problem on a 47 D. I took the radiator to a professional welder and he could not weld it. The metal is very thin and will continue cracking in advance of welding. I ended up using a fiberglass kit on it after I ground off all the old weld, paint, rust, etc. I let it cure for about a week or 10 days before adding water and it held fine. Of course, if the water ever gets real hot, I don't know what will happen, but for now it is holding. Good luck! David
Glen in TX
08-06-2005 20:46:47
Wes, Use a cherry picker or hoist if pulling that radiator by yourself for sure. I'm not sure what it weighs but its heavy all right. Sounds like a crack in the lower tank which is common on those. You said three bolts on top so I'm figuring you mean a styled D 39 and up. That top gasket for the 3 bolts under radiator to water pipe is D3008R. I have sometimes stacked 2 or even three gaskets there and used a good high heat silicone sealer and let it cure before running. I know the parts book only shows one gasket but the surfaces have probably eroded away some on the water pipe top and bottom. You can make gaskets from some thick gasket material or JD should have them. If not I should have those too or contact [email protected] in Colorado.
Wes
08-08-2005 11:29:29
 Re: D Radiator in reply to Glen in TX, 08-06-2005 20:46:47
Glenn and the rest thanks for information. Took it off today and it is at the welding shop as we speak. Yes its a 49 D.
Glenn if you have the upper gaskets send me a EMAIL at [email protected] with your phone # and I will call you about getting gaskets from you.
Thanks
Wes
