Anyone try the tapered o ring 4020?
Nylon
08-05-2005 23:24:48
Anyone actaully install the aftermarket tapered bushing and o ring on the 3 point (Hitch)? Wondering if it really does work. My leak isn't too bad but if I have to drain to do brake work I may as well try popping out and doing those bushings if they are tried and true.
Thanks,
John
Mike M
08-06-2005 05:33:15
 Re: Anyone try the tapered o ring 4020? in reply to Nylon, 08-05-2005 23:24:48
I installed a set on ours at least 10 years ago on good advice from a local that repairs lots of 4020's still dry. I would put some in as it can't hurt anything and just adds an extra barrier. You still use the original seals on the outside too.
I also put in a new shaft
08-06-2005 05:34:37
 Re: Anyone try the tapered o ring 4020? in reply to Mike M, 08-06-2005 05:33:15
I would install a new shaft . The aftermarket sells these too.
