What plow for a 48 B?
48Bboy
08-05-2005 12:44:26
Will a 48 JD B pull a 2 bottom plow that attaches to the 3pt.
DW
08-06-2005 15:02:28
 Re: What plow for a 48 B? in reply to 48Bboy, 08-05-2005 12:44:26
I pull 2/16s pull type plow with my '50 B so you should be able to equal that at least with a mounted plow.
James Nauert
08-06-2005 03:19:17
My 51 B pulls two 14's with ease. You will need to have the minimum of a set of rear wheel weights i have the tires loaded on my B.
Dick Dillman
08-05-2005 14:20:42
Hello 48Boy; If your 48 B is in decent shape, it should handle a 2--14in. or even 2--16in. mounted plow under most all conditions. DickD
old
08-05-2005 14:26:06
 Re: What plow for a 48 B? in reply to Dick Dillman, 08-05-2005 14:20:42
I pull a 2 bottom 14 plow with my 1935 JD-B and it does ok with it and your B would have more power then my old B has
