Best loader for a 2510
Lambert
08-05-2005 12:01:22
About to give up finding the brackets and frames I need for the 47 loader I kept off my 1020 hoping to use on my 2510. Any comments on what would work on and be the best loader for the 2510? I have been told the 48 would work with no problems, but guess there might be others.
Glen in TX
08-06-2005 07:26:06
 Re: Best loader for a 2510 in reply to Lambert, 08-05-2005 12:01:22
Check with your local JD dealer salesman and partsman as they should have some info on what fits or what can they get or have to fit one up. Not finding the 48 at JDparts.com but they do show brackets on parts books there for 145 & 148 but it doesn't tell if they will a 10 or 20 series. I have new operators manual for a 48 loader and its shows it fitting 1020 & 2020 utilities and 2510,302020,& 4020. Pics show what looks like two different mounting brackets.
buickanddeere
08-06-2005 06:35:14
The 2510/2520 do not have a beefy front end for HD loader use.
Doug in IL
08-06-2005 06:51:15
 Re: Best loader for a 2510 in reply to buickanddeere, 08-06-2005 06:35:14
A quick check of the parts book will show that the 2510 uses the same wide front end as a 4320. Yes, that front end maybe a bit light for a 4320. But it's plenty strong enough under the lighter 2510.
Lambert
08-07-2005 10:14:16
 Re: Best loader for a 2510 in reply to Doug in IL, 08-06-2005 06:51:15
Thanks for the info. My Dad had a couple of 4320's over the years and they were quite the horse. My 2510 has a bigger front end than my 1020 did and it stood up ok for what I do.
Tx Jim
08-06-2005 03:58:26
Lambert,a JD 48 will work on 2510 but you could run into same mounting frame problem as you already have as they would fit utitity tractor also.Tx Jim
Lambert
08-06-2005 06:21:33
 Re: Best loader for a 2510 in reply to Tx Jim, 08-06-2005 03:58:26
Thanks for the info. Just so I understand, you are saying the 48 came with different frames to match diffent tractors too? Any way to determine which 48 will work with my 2510?
vtstew
08-06-2005 07:04:15
 Re: Best loader for a 2510 in reply to Lambert, 08-06-2005 06:21:33
The loaders will be the same just the mounting brackets are different from the utility tractors to the row crops... I have run a 48 on both. the loader is now retired out back
Lambert
08-07-2005 10:18:52
 Re: Best loader for a 2510 in reply to vtstew, 08-06-2005 07:04:15
Thanks. When you say retired, does that mean no longer in usable condition or just no longer using? If still in good condition and was on a 2510, I could be interested to buy if you are interested to sell.
Paul in WI
08-05-2005 15:54:15
I put a 145 loader on my 2510. I can send you pictures if you like. Paul
Wannabe
03-22-2006 05:50:28
 Re: Best loader for a 2510 in reply to Paul in WI, 08-05-2005 15:54:15
I have the chance to buy a 145 loader for my 2510 and was curious if you are happy with your setup and how hard it was to get mounting brackets.
Also, I would appreciate any advice on mounting the loader if I buy it.
Thanks for any help
Lambert
08-06-2005 06:18:06
Pictures would be helpful, thanks.
dads730
08-05-2005 14:58:05
I have a 48 loader on my 2520 and it works great! I would assume you could also put on a 148 but you are talking more money.
